Hi;
I designed a PoE according to reference http://www.ti.com/lit/ug/slvu301/slvu301.pdf. However, generally design could not start easily. First of all, you hear "zzzz" sound from POE300F-50L and you get no output. Then, If you touch the DT and BLNK pin, design works fine. If the design works fine with no load, board will not start to work with load (1A) in general.
I tried this at 15-20 different PCB. I think resistance of the DT and BLNK pin does not choosen correctly.
How can I solve this problem?
Thank you,
