I am concerned with regard to figure 6 of slva306a.pdf:
Doesn't the body diode of the MOSFET Ma effectively ground the negative input of the power adapter and render the disconnect circuit useless?
Hi Darwin,
thanks for the quick answer: So the FDC2512 will work but figure 6 has a wrong N-channel FET symbol where the body diode is shown in reverse?
Michael
Hi Michael,
That's correct, after looking at the FDC2512 the diode is the other way around.
