What is the best way to latch OFF the TPS device with only a short signal? With the EN pin pulled low I can only disable the device as long as I can hold the EN pin low which is only as long as the microcontroller has power (powered from the TPS).
I can make a external latch for pulling the EN low until the next power cycle but I would like to know if there is some other option like getting the device in a fault state so it stays OFF until the next power cycle or something similar?
Thank you.
