Other Parts Discussed in Thread: TPS2372, TPS23880, TPS2388
In the datasheet it is seen that i need to give Vc_In (8.5V <Vc_in<15V) to the IC for proper operation.
So, if i am powering a non isolated synchronous Buck converter, should i design an extra circuit to give this bias voltage and regulate it to the said voltage?
Kindly shred some light on the circuit configuration when using TPS2373 with a buck converter.
Arjun
