Hi Experts,
Can you help to take a look at attached customer's schematic for TPS23861 2-port PSE application? If only 1pcs device has been used, how to deal with AOUT/AIN pins?
Thanks a lot!
Hi Experts,
Thanks a lot!
Hi Jacky,
For the PSE part in schematic, here are the comments:
1. It would be better that unused SENSE pins are connected to GND
2. Capacitors between GATE and GND like C1509-C1512 should be removed, this will impact the speed of MOSFET turn on and off
3. If only 1pcs device is used, AOUT pin can be floated, AIN pin can be floated or grounded
Thank you
Best Regards
Jack Chen
