TPS23754: The difference of TPS23754 and TPS23754-1
Part Number: TPS23754
Other Parts Discussed in Thread: , TPS23756
Hi sir,
I have doubt about Tps23754 and Tps23754-1, Could you tell me the difference between them? By contrast, I found the datasheets are same. Thanks a lot.
Jenny
  • Jenny, Thank you for your question.
    The TPS23754-1 replaces the PPD pin with a no-connect for increased pin spacing. This information can be found on page #1 of the TPS23754, TPS23754-1, TPS23756 shared datasheet in the "Description" section. A description of this pin functionality can be found on page 3 of the datasheet for your consideration.
    Please let us know if needing anything else and thank you for considering Power over Ethernet (PoE) solutions from TI.
