Other Parts Discussed in Thread: TPS2372, TPS2373, LM5116, PMP20541
May I have your upport about TPS2372-4EVM-006 Altium/Board Files?
Thanks.
Eric
Thanks.
Eric
Hi Thomas,
No, I need Original schematic & PCB Layout file. Such as Altium/ Orcad...
Thanks.
Eric
Hi Thomas,
Thanks your support but I hane another question about TPS2372 design spec
Vin: 48V
Vou:12V/3A
Would you kindly suggestion buck solution with TPS2372 PoE design?
Thanks.
Eric
Hi Thomas,
OK and thanks your help.
Then I also need flyback DCDC with TPS2372 or TPS2373 reference design.
Thanks.
Eric
Hi Eric,
What efficiencies is required for the buck solution? Because the efficiencies tend to be low, an isolated converter is designed for this power level which is why looking at the TI design library there is no buck that is recommended. However, if needing a buck solution, I recommend the LM5116. In the link below, there is design calculator to help you design the buck solution and you can pair with the TPS2372.
For the flyback solution, I recommend pairing the below TI design with the TPS2372.
Please let me know if this helps! Thanks!
Hi Darwin,
May I have your support to review TPS2372-4 PoE schematic as attached?
Thanks.
Hi Darwin,
May I have toyr support to review TPS2372-4 12V/4A PoE schematic as attached?
Thanks.
Eric
