• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Power Interface » Power Interface Forum » 300mA to 500mA current limit needed for 5V output
Share
Power Interface
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Toshiya Hiramatsu
Posted by Toshiya Hiramatsu
on Nov 03 2010 22:55 PM
Intellectual630 points
I have a question for the way of current limiting.
I'm using LM2575.
I'm looking for the way of limiting the current by using an external circuit.
The limiting current value is between 0.3A and 0.5A.
I hope for the simple expedient.
Could you please teach me?
For instance, how about Fig-28 in the TL431 data sheet?
Thanks & Regards,
Toshiya.
current limit LM2575
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Glaser
    Posted by Chris Glaser
    on Nov 04 2010 08:04 AM
    Guru58715 points
    The best option will depend on what voltage you want to current limit.  What is the output voltage of your LM2575 circuit?
    Yes, the TL431 circuit will work as a current limiting circuit.  However, using the TLV431 will be twice as efficient, as it has a lower Vref.
    TI also offers a broad protfolio of current limited switches.  You can look through those here: http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?family=analog&familyId=423&uiTemplateId=NODE_STRY_PGE_T
    Report Abuse
    • Reply
  • Toshiya Hiramatsu
    on Nov 04 2010 20:10 PM
    Hello! Chris-san,
    Thanks for your quick response and advice.
    I'll use LM2575 by output=5V and input=12V.
    I'll try to see the web page.
    Thanks & Regards,
    Toshiya.
    Report Abuse
    • Reply
  • Chris Glaser
    on Nov 04 2010 21:55 PM
    Guru58715 points
    Yes, with a 5V output, you have many options.
    This is really a power interface question, so I will move this post to the power interface forum.  They can help recommend the right part.
    Report Abuse
    • Reply
  • Martin Patoka
    Posted by Martin Patoka
    on Nov 05 2010 07:46 AM
    Verified Answer
    Verified by Chris Glaser
    Expert6570 points
    The TPS2552 is a programmable current limit protection device designed for 5V rails (e.g. USB and so forth).  It  has better accuracy than you requested.  The TPS2552 would be put on the output of the switcher.
    Make sure that the switcher output ripple is well controlled so as to not have a large influence on the programmed current limit.  This would be caused by large converter ripple applied to large, low ESR capacitors downstream from theTPS2552 causing large switcher ripple to want to flow through the TPS2552.  In mathematical terms, Z(switcher output caps) << Z(load) at the swithcher fundamental frequency.
    I suspect that you were thinking of placing the TL431 limiter on the input side of the switcher.  You might find there are issues with switcher startup and input ripple current affecting the desired operation.
    The switcher you have chosen seems to be a little older, considering the rapid advances in switcher ICs.   A shortcut to a selector guide is through www.power.ti.com which has a quick selection tool at the top (12V -> 5V @ 1A).  I found the TPS5410 there as a similar, but more advanced part.  This has an internal MOSFET, and there were also controllers there that might be of interest.
    Report Abuse
    • Reply
  • Toshiya Hiramatsu
    on Nov 07 2010 21:44 PM
    Hello! Martin-san,
    Thanks for your response and detail explanation.
    I think that TPS2552 is good!
    I would introduce TPS2552 to the customer.
    By the way,I was thinking of placing the TL431 limiter on the output side of the switcher.
    Thanks & Regards,
    Toshiya.
    tl431 tps2552
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
