Hey everyone,
I plan on using four paralleled csd19535ktt on a pcb to share a large amount of current ( as their rated for a large amount) although the source pin is insanely small and there is no way i could get the track thickness down to 1mm.
Could i make the track that connects to the source terminal thicker than it is so that the track doesnt just burn out? I know the current is well within the mosfets range although not close to pcb range for tracks ( around 50 Amps)
Thanks in advance
