Hi Team,
My customer want to know below details. I mentioned that he should look at the power loss graph for his Rdson/Trise/Tfall , however he still need your help on below.
I hope you understand that it is important to have as much possible insight in the design i.c.w. TPS53x61.
- What is the Coss of the bottom FET, this to estimate the dissipation of a potential snubber resistor or some advice – guidelines regarding the snubbers?
P.S. Regarding the power losses of power stages our case is similar with the one on the graph, different switching frequency (600kHz) and Vout (1.3V-1.8V) but if no data is available I can make some assumptions and proceed. Thank you.
Thanks a lot again,
