I would like to have a graph of IDSS Drain-to-source leakage current Vs VDS and Temperature range for CSD13380F3. Thanks in advance.
Hi Bertt,
This information is needed as I am designing battery/energy harvesting based, high efficiency, ultra low leakage load switch circuitry for IoT applications. TI's MOSFET CSD13380F3 is pretty much meeting the requirements but I don't have the requested info for a robust SoA design and guaranteed performance over its 10-year lifespan.
-Krish
Brett, do you understand what is the meaning of MAX ratings in a datasheet? It means the guaranteed figure not exceeding within the test conditions. If the datasheet doesn't cover its entire operating temperature range for a specific technical character, there is no way to design a circuit reliably until unless you have your own test equipment to get these characteristics. Hope you understand these basics.
