CSD18541F5: Datasheet values
Part Number: CSD18541F5
Can you please check on datasheet values.
Seem to be quite high.
RG 1200Ohm
td(on) 572ns
tr 540ns
td(off) 1076ns
tf 496ns
  • Guenter,
    The datasheet values are correct.
    The high switching times are a function of the high Rg and the high Rg is due to the added ESD protective Diode.
    This part is meant to act as a load switch and was not designed for fast switching applications.
