I am using LMZ31710 in current sharing mode. Is this module recommended to use with current sharing and split voltage options?
If i can use, is it compulsory to give external SYNC clock? I can not provide this externally, shall i give Rrt for first module and connect SYNC output to RT/CLK of second pin?
and is it required to connect Rrt resistor for second module also?
please clarify these doubts..
Thanks in advance,
Mahesh.gv
