Hello.
Would there be data next to PTH12000WAH?
1 PTH12000WAH Pin to Pin short test results.
2 Pin open test results.
3 Pin to Vin short test results.
4 Pin to GND short test results.
Thank you.
Hello.
Thank you.
All PTH power modules are 100% electrically tested prior to shipment .
Any not passing the final test will be scrapped.
Tom
hello.
Tom san.
Thank you very much for your answer.
Material of attached documents is a sample dater.
Would there be data of same PTH as a sample dater?
The contents
thank you。
Masazumi Ishii:
Thank you.
PTH12000W and all PTH power modules are complete power circuits.
The final (ATE) outgoing parametric electrical tests are completed on all production units. We test each entire module for operational functionality on all 5 power pins .If the unit does not pass the functional electrical parametric tests, it will not be released.
Additional questions you can contact me at tguerin@ti.com
Tom
