PT6940 Replacement design
The PT6942C is no longer available, but I need to be able to build more boards that use that component.  I have received information about several alternates, but none are Form Fit and Function for the original.  I would like to design a replacement module that does not require me to modify my circuit card layout.  To do that that I would like to know if I can obtain the detail drawing information for the mounting frame/heat sink used on the PT6940 family of power supplies and information about mounting the pins used to connect the power supply board to the user circuit card.  Is this information available for me to use?
