Is anyone who could give me some proposals to reduce the spike? Thanks very much.
SIYUAN:
Can you send me your exact schematic with input and output capacitors including ceramic capacitors. What is the input voltage and output voltage , and output current.? It appears the ± pulse is directly coupled from other power circuitry to the PTN78020W out put bus. I suggest you add a small resistive load on Vout pins of PTN78020W. 50-100 ohms.
Tom
I configured the DC-DC converter the same way as what the data sheet required. The input voltage was 15V from bench supply and the output voltage was 2.5V to diode load. I think that you are correct that -+pulse was coupled from other power circuitry which the bench supply's switch bouncing. Could you tell me please where to add the recommended resistor?Across the converter's output to gnd or in series with my diode load? Also, why you think add a resistor will possibly make it better?
Thank you very much.
Siyuan
SIYUAN:
I would add the resistor directly across the Vout power trace to ground.
This will likely introduce an low impedance path to ground before PTN78020W initiates normal power -up.
Tom
