PTH08T240W: PTH08T240W parallel power supply operation
Part Number: PTH08T240W
Other Parts Discussed in Thread: LMZ31520
Team,
My customer is leveraging an old design that uses PTH08T240W circuitry that he cannot change.
He wants to use a second power supply in parallel and disable PTHxxx with INH/UVLO pin and then apply the second supply to the same output. The output pins of both supplies are tied together.
The concern is if the second supply being applied to PTH08T240W output (but going to the load) while PTHxx INH/UVLO pin is tied low will cause any undesirable results.
Do you have any concerns with this approach?
Kevin Ginunas
Analog FAE
