Hi
I have this task. Find a gate driver that can to the job on the attached schematic.
The driver must not be making noise on the output-DC-signal - eg from refreshment of gate-chargement.
Do you know such a driver?0743.Sheet1.pdf
Hi
Hello Martin,
I am an applications engineer for high power gate drivers.
Are there any other requirements needed for the gate driver besides isolation?
What is the part number of the FET being driven here?
regards,
Mateo
Hi Mateo
Theres no special mosfet on the table. Just a "fast one" that can withstand about 500Vds. We use to built the gate drivers with a refreshment of the gate-charge - but this is a bit noisy for some applications.
regards
Hi Mateo - thanks for the advice.
I will try it out.
I did not know it could run with negative rail as well.
regards
Hi Mateo
Which kind of power supply can be used for the gate-driver?
I would prefer a linear to avoid switch mode noise.
However in my test setup a linear lab supply seems to be to slow.
regards Martin
