Dear all,
I need a converter from +5V to -5V and 0.3A output current. I want to use LMZ21701 which is already used in our design as a buck converter.
But in my application I will use it as negative buck boost. In some application notes I have seen that it is possible to use synchronous buck converters to generate negative output by connecting the output voltage to ground and ground terminal of the device to negative output. But in LMZ21701 datasheet I haven't seen anything about negative buck boost operation.
My question is that is it possible to use it as negative output buck boost ? Is there something important to take into consideration when we use it as buck boost?
