LMZ14202EXT: Screening and Qualification Information
Part Number: LMZ14202EXT
Hello, my name is Gabriel and I work at TEKEVER, Portugal.
We are currently using the referred component in a space intended project.
Given the nature of our application, we are required to qualify every component according to standards.
However if you have already performed any test on any of these components it would be most valuable and time saving for us to have knowledge of those tests, which include, for example:
- Preconditioning + HAST or THB
- C-SAM inspection
- Thermal Cycling / Shock
- Lifetest
The test conditions are not important, so if you have done any of these tests or other kinds of tests that may comply to any MIL-PRF or STD, it would be most helpful in our qualification process.
Keep in mind that we are aware that some components may not be specific for space applications, however the mission in which these components will be part of, is going to provide a controlled temperature and radiation environment, thus the use of commercial components being allowed.
Thank you and best regards.
