Hi All, can anyone please let me know the following for PTD08A020WAD:
- How is the output voltage set for PTD08A020WAD? i was not able to figure that out from the datasheet . Is it digitally programmed , if so how?
- Temp pin voltage as a function of temperature
- Table4 of the datasheet gives the capacitor parameters : does this indicate two 47uF capacitors are internal to the module ?
