• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » SIMPLE SWITCHER® » SIMPLE SWITCHER® - Forum » lmz10501 - ouput capacitance
Share
SIMPLE SWITCHER®
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Amit Benjamin
Posted by Amit Benjamin
on Oct 25 2011 11:36 AM
Expert6700 points
Team,
One of the strategic defense companies had inquired about the nano modules.
He would like to use 100uF output capacitance but saw a comment in the datasheet that this can lead to a current limit.
Could you tell what need to be done in order to allow this output capacitance?
http://www.national.com/an/AN/AN-2167.pdf
thanks
Amit
Amit Benjamin,
Analog & Power FAE
Texas Instruments, Israel,
Cell     +972 54 6663791
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Allan Fisher
    Posted by Allan Fisher
    on Oct 25 2011 14:57 PM
    Intellectual1155 points
    Amit,
    What is their reason to use 100uF of output cap?
    I will forward to the apps engineer responsible, perhaps he has some advice.
    Allan
    Report Abuse
    • Reply
  • Amit Benjamin
    on Oct 25 2011 15:01 PM
    Expert6700 points
    I believe they are powering FPGA and 47uF is considered to be too marginal capacitance.
    They afraid to have a marginal design.
    What can issues might appear if using a higher capacitance? Stability issues?
    Amit
    Sent: Tuesday, October 25, 2011 9:58 PM
    To: int_nonisolated_dcdc_forum@e2e.ti.com
    Subject: Re: [INT - Non-Isolated DC/DC Forum] lmz10501 - ouput capacitance
    A Message from the TI E2E™ Community
    Texas Instruments
    Amit,
    Allan
    View this message online or reply to this message
    E2E http://www.ti.com/e2e-community
    Report Abuse
    • Reply
  • Denislav Petkov
    Posted by Denislav Petkov
    on Oct 25 2011 15:32 PM
    Expert4870 points
    Hi Amit,
    Having too much output capacitance may prevent the output from reaching the 0.375V at the end of the startup sequence. In such condition, the part will think there is a short circuit on the output and enter the hiccup mode described in Figure 3 (page 14) of the datasheet.
    The maximum output capacitance to reach this condition depends on the output voltage configuration, the Vcon capacitor value, and the loading on the output. Table 1 (page 16) of the datasheet lists out conservative maximum capacitance values for several typical output voltage conditions. It assumes full load on the output and 1nF Vcon capacitor.
    A couple of questions for you:
    1. What is the application's output voltage and load current?
    2. Why is 47uF output capacitance considered marginal in this application?
    Denislav
    Report Abuse
    • Reply
  • Amit Benjamin
    on Oct 26 2011 09:33 AM
    Expert6700 points
    Hi Denislav,
    Please see the answers to your questions below -
    1.2V/1A
     The FPGA required to have 100uF of coupling and bulk capacitors.
    Reading the datasheet, you clearly can see that it is recommended to not using more than 47uF for 1.2V output.
    Could you advise how we can safely use the nano module for this application? Is there a way to tune the soft start?
    Amit
    Amit Benjamin,
    Analog & Power FAE
    Sent: Tuesday, October 25, 2011 10:33 PM
    Subject: RE: [INT - Non-Isolated DC/DC Forum] lmz10501 - ouput capacitance
    Texas Instruments
    Hi Amit,
    Denislav
    Report Abuse
    • Reply
  • Denislav Petkov
    on Oct 27 2011 18:47 PM
    Verified Answer
    Verified by Denislav Petkov
    Expert4870 points
    Hi Amit,
    The softstart time can be slightly reduced by reducing the VCON capacitor. However, that would still be insufficient to start with a 100uF output capacitor. Even 68uF would be challenging.
    We can try other tricks involving 2-3 resistors, a capacitor, and a small signal BJT/FET and a diode and try to jump start it with a larger output capacitor. I am not sure if this is a good solution and may defeat the purpose of using a nano module. Please contact me directly with some details about the opportunity if you still want to explore that path. We would have to know the input voltage and whether they are using EN signal (and its voltage level).
    Denislav
    Report Abuse
    • Reply
  • Alexey Grehov
    Posted by Alexey Grehov
    on Apr 04 2013 04:59 AM
    Prodigy20 points
    I'm interested in this solution too.
    Generally LMZ10501 is very convenient module to use it for fpga. Xilinx require 100+ uF capacitance in series of voltages.
    Vccint for Spartan-6: 1.2V requires 105 uF
    Vccaux for Kintex-7: 1.8V requires 108 uF
    It would be nice if we can use such small module in such cases.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
