• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » SIMPLE SWITCHER® » SIMPLE SWITCHER® - Forum » Converter IC for buck- bost application, choosing between LM5576 & TPS54260 !
Share
SIMPLE SWITCHER®
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
  • Michal Grabarczyk
    Posted by Michal Grabarczyk
    on Dec 14 2011 15:30 PM
    Prodigy30 points
    Hello All,
    This is my first project connected with DC/DC converters. Therefore all kind of remarks will be appreciated.
    I have to design buck-boost converter (inverting configuration) meeting following requirements:
    U in_min = 6V
    U in_max=  36V
    Uout = - 5V
    I out_min = 28 mA
    I out_max =1A
    I out_typ  =  100-200mA
    Moreover an  important issue is also converter footprint.  It have to be as small as possible.
    I tried to use WEB BENCH and SWITCHER PRO software. Once the input data is processed WEB BENCH gives only two possible solution with LM5576 & LM25576.
    In  SWITCHER PRO  I can't define output voltage with value  less than 0. It looks like inverting configurations aren’t  implemented .  Is that right ?
    Any way I found some IC form TI side, which may meets requirements  - TPS54260.  In datasheet is  showed  that it can be used in inverting configuration. It have also small footprint.
     I also found  application note SLA317a and excel  used to calculate parameters values for this IC.
    There are few questions which I have at this stage of design :
    1.Are there any difference in operating between LM5576 & TPS54260 working as buck- boost converter  ( taking my requirements into account)   ?
     2. Does anyone have experience with TPS54260 as buck-boost converter , with similar specification?
    3. What else design support I can get beside SLA317 application note? Do you know why WEB BENCH doesn't include this solution?
    4. What about evaluation board for buck-boost converter? Can I use standard board for TPS54260 and just switch the output signals (OUT to GND, GND to OUT).
    buck-bost lm5576 TPS54260
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • David Daniels
    Posted by David Daniels
    on Dec 14 2011 17:22 PM
    Intellectual1125 points
    Michal Grabarczyk,
     Thanks for the interest in a TI power solution.
    In both cases, you are using a step down regulator as an inverting supply.  The enable and clock synchronization will be referenced to chip's ground which will now be the system's negative voltage.   If you are coupling these pins to other components in the system you may need to level shift.
    The TPS54260 has a smaller package (msop or son) and higher switching frequency which you can use smaller inductor and output capacitors.
    Both devices are externally compensated which can the changed to compensate for the inverting buck boost.
    Using the TPS54260 and derivative devices is a popular method to create a negative rail, hence the app note and excel sheet.
    This inverting configuration can also create a positive/negative supply by using a catalog coupled inductor (see slva369).
    The slva317a app note and excel sheet are best method we have to instruct on how to use the device until the webench integration.
    Many users tweak a standard step down evm by adding a bulk capacitor from VIN to VOUT, changing the inductor and frequency compensation to evaluate the inverting configuration.
    Thanks Again,
    David
    Report Abuse
    • Reply
  • Allan Fisher
    Posted by Allan Fisher
    on Dec 16 2011 18:09 PM
    Intellectual1155 points
    A couple other good options are the LM22680 and LMZ14202 module, which has the advantage of an integrated inductor.
    Refer to the following documents:
    http://www.ti.com/lit/an/snva425/snva425.pdf
    http://www.ti.com/lit/an/snva363d/snva363d.pdf  This app note is for the LM22670, but applies also to the pin to pin compatible 22680.
    Allan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
