What is the expected failure mode of the LMR12010X when the BOOST pin is left floating?
Hello Victhor,
If you leave BOOST floating, the internal gate driver will not have enough voltage to properly drive the NMOS switch and the output voltage will not be regulated. The NMOS switch will probably heat up due to higher power dissipation if the output of the regulator is loaded.
Denislav
Thank you, this coincides with the results of testing I have performed.
