• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » SIMPLE SWITCHER® » SIMPLE SWITCHER® - Forum » LM2674 minimum input and output capacitors
Share
SIMPLE SWITCHER®
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Joerg
Posted by Joerg
on May 08 2012 17:34 PM
Prodigy135 points
What is the minimum input and output capacitance if we use only ceramic caps? Ripple is not too important but board space is. The datasheet only gives examples of certain manufacturers which does not help us. I wish there was a "real" datasheet for SimpleSwitcher chips. Those "recipe sheets" aren't so great.
Joerg
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ismail Jorio
    Posted by Ismail Jorio
    on May 08 2012 19:58 PM
    Prodigy675 points
    Hi Joerg,
    LM2674 is internally compensated and the sizing of the output cap will depend on the duty cycle and the inductor value chosen.
    For the input capacitance, it is important to put enough capacitance to handle the voltage transient in the input which really depends on the duty cycle. The RMS current of the caps should be chosen around 1/2 the DC inout current to avoid saturation.
    You can also use our Webench tool for your particular design which provide input and output capacitor values. www.ti.com on the lower left corner.
    Ismail
    Report Abuse
    • Reply
  • Joerg
    Posted by Joerg
    on May 08 2012 21:57 PM
    Prodigy135 points
    Hello Ismail,
    Thanks. However, I cannot use WebBench because my firewall blocks it. Seems it wants to use some sort of flashplayer routine. I know about the input spike, my supply will be very low impedance, just need to know how much is needed for stability. For example, for most comparable Linear Technology converters it is 1uF if you use ceramic caps.
    For the output I'd need to know how well it can regulate out a full load swing to 300mA and back to almost zero without under/over-shooting more than 150mV or so. Normally I do this with SPICE but as far as I know there are no models for your converters.
    Joerg
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 09 2012 14:03 PM
    Prodigy675 points
    Hi Joerg,
    Based on the output current change you mentioned, you can calculate the change in input current based on your input to output voltage ratio. An input cap value, that is big enough to stabilize the input voltage while supplying the current.
    For the output Cap, it is part of the transfer function and you need to choose an LC filter that will guarantee a double pole frequency occuring way below the switching frequency and keeping your system stable with the internal compensation provided on the block diagram.
    The advantages of ceramic Caps are size and low ESR. So if you want to use Cermaic caps you will remove the ESR componenet from the transfer function equation.
    You mentioned that your load step is 200mA and another 300mA with less than 150mV under/overshoot.  What is your input and output volatges? your nominal output current?
    Ismail
    LM2674
    Report Abuse
    • Reply
  • Joerg
    Posted by Joerg
    on May 09 2012 16:57 PM
    Prodigy135 points
    Hello Ismail,
    No chance to put an LC filter there and we don't really need one. Input is 16-32V and output just a few hundred mA. We can keep it under 300mA but that can swing quite a bit, for example from 100mA to 300mA and back. It's probably best to use a chip with an external comp node, and one I can simulate in SPICE.
    Joerg
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 09 2012 20:17 PM
    Prodigy675 points
    Hello Joerg,
    I was referring to the LC of the buck. Fr=Sqrt(LC) will be the rolleover Freq. You can simulate the circuit on spice if you use the control section from the block diagram using two Gm amplifiers.
    Using webench, with your input range and 5Vout, you will need 10uf on Cout and 1uF on the Cin but you will need 220uH inductor to stabilaize your circuit.
    Ismail
    Report Abuse
    • Reply
  • Joerg
    Posted by Joerg
    on May 10 2012 17:58 PM
    Verified Answer
    Verified by Ismail Jorio
    Prodigy135 points
    Hello Ismail,
    Thanks. That is way too big of an inductor in this case, then we will have to use another chip.
    As for Webbench, I was never too enthused about that program. Many times it said that the design can't be done (and it's all in production since years ...), other times I really needed a bit more than just a cookbook recipe. For example optimize load change reactions with phase lead caps and so on. A SPICE simulator is much better for that but one must have models with some stuff in behavioral format in there so simulations don't take forever.
    Joerg
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 14 2012 18:12 PM
    Prodigy675 points
    Hi Joerg,
    This inductor value was chosen conservatively for 5Vout and 0.5mA. This part is old and we dont have a model for it. you can use our LM2267X family that are better parts and we can create a model for you that you can simulate.
    Just give me the exact conditions and I will put a request for you.
    Ismail
    Report Abuse
    • Reply
  • Joerg
    Posted by Joerg
    on May 15 2012 09:34 AM
    Prodigy135 points
    Hello Ismail,
    Thank you for the offer to request a model, that is very kind. But unfortunately I am nearly out of time, the whole circuit design (with a lot of other stuff) has to be done by Friday. So for this design I had to use another IC where there already is a simulator model.
    When you discuss things like this with managers, maybe at a meeting, let them know that SPICE model availability is very important these days. Nearly all my designs are born on the PC now, on the simulator. I see others do the same. With a switcher IC this is not so easy and it is often best to have some functions in there described as behavioral (mathematical). Otherwise the simulations take forever. I had that case with a UC-something switcehr chip from TI last year, simulation runs could easily take half an hour.
    Joerg
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
