• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » SIMPLE SWITCHER® » SIMPLE SWITCHER® - Forum » LMZ14201 enable input 5V control circuit
Share
SIMPLE SWITCHER®
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Valentin Serb
Posted by Valentin Serb
on May 11 2012 16:31 PM
Prodigy90 points
What would be a suitable enable circuit for the LMZ14201 that is NOT powered from Vin? I need to drive this input from an external 5V and got totally confused by this statement in the datasheet:
"The EN pin is internally pulled up to VIN and can be left floating for always-on operation"
Does it mean I cannot drive this from a 5V input as there will be current flowing back into this input since VIN is usually higher than 5V? I need the switcher to be OFF when 5V input is not active, and turn it ON when the 5V input becomes, well... 5V
TIA,
Valentin
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ismail Jorio
    Posted by Ismail Jorio
    on May 11 2012 17:21 PM
    Prodigy675 points
    Hi Valentin,
    The EN pin is internally tied to Vin but you can tie a 5V source to it to control turn and tun off. The pull down current is 6uA, in significant compare to the switching current.
    EN needs to be high (>1.2V) for the part to work. If you decide to tie to vin, make sure not to exceed 6.5V on EN by using a zener diode.
    You can also have a voltage divider from Vin to En in reference to 1.18V to change the UVLO option.
    Ismail
    Report Abuse
    • Reply
  • Valentin Serb
    on May 11 2012 17:35 PM
    Prodigy90 points
    Thanks for the prompt reply! The 5V input is actually an optoisolator transistor output, and I am not sure the current can flow backwards. What is the VIN pullup resistor value, and is VIN the source for the 6uA current?
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 11 2012 17:57 PM
    Prodigy675 points
    depending on the optoisolator transistor, if iti s open drain or open collector it will take current. What is the part number for the opto?
    Vin is the source of the 6uA current.
    Report Abuse
    • Reply
  • Valentin Serb
    on May 14 2012 13:41 PM
    Prodigy90 points
    The optoisolator PN is ACPL-217-500E. It has a NPN output photo-transistor, and (unlike a MOS transistor in saturation) I don't think I can swap the collector and emitter as far as the current flow is concerned. Is there another circuit you could recommend?
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 14 2012 17:51 PM
    Verified Answer
    Verified by Marc Davis-Marsh
    Prodigy675 points
    Hi Valentin,
    In order to pull EN high using the opto mentioned above, just tie the collector to a rail lower than 6.5V and the emiiter to EN. when the light turns ON, the BJT is ON and the EN is pulled High from the rail. In this configuration, you will need a resistor to pull it low. Make sure you size the resistor to En is above 1.2V
    If you have the opto as pull down, connect the collector to En and Emitter to ground, when the light turns ON, the BJT is ON and the En is pulled to GND.
    Ismail
    Report Abuse
    • Reply
  • Valentin Serb
    on May 28 2012 17:10 PM
    Prodigy90 points
    Thanks for your answer! I am not sure I understand what you mean by "you will need a resistor to pull it low"? Could you please be a little more specific?
    Valentin
    Report Abuse
    • Reply
  • Ismail Jorio
    on May 29 2012 14:30 PM
    Prodigy675 points
    Hi Valentin,
    When you tie a node low (to GND), you need a resistor in the K Ohm range to limit the amount of current drawn from that pin. Ohm's law principle.
    Ismail
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
