• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » SIMPLE SWITCHER® » SIMPLE SWITCHER® - Forum » LM2596/LM2676/LM22680 X GPRS Power Supply
Share
SIMPLE SWITCHER®
  • Forum
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Jeferson Pehls
Posted by Jeferson Pehls
on Aug 02 2012 21:09 PM
Intellectual770 points
Hi.
I have a GPRS product based on an embedded module.
This GPRS module have a power supply with a 4,2V output with a maximum medium of 300~350mA current consumption.
Curently, I am using a power supply based on a LM2596 (fsw = fixed at 150Khz only). Since a all GPRS modules present a high peak current consumption during data transmissions, I think I will need a faster power supply.
I saw the LM2676 have fsw fixed at 260KHz, and I think I will start using it instead of keep using the LM2596 - SMD TO263. I will update the power supply next month and the controller IC is one of the key parts of the power supply.
I was also thinking to use the LM22680 SMD SOIC-8 for this design
Input voltage range is from 10 to 32V only.
Question:
Is LM2676 or LM22680 suitable for my project? For GPRS modules?
Please give me some other suggestions, if possible.
What is the part numbers of developments boards for these ICs?
Please check the attached PDF. It shows the power supply requirements.
0820.GPRS_power_supply_specs.pdf
http://www.digikey.com/scripts/DKSearch/dksus.dll?Detail&itemSeq=117672525&uq=634795359243376141
http://www.digikey.com/product-detail/en/LM22680MRE-ADJ%2FNOPB/LM22680MRE-ADJCT-ND/1993220
I also would like to know which value range (if there is a standard value) of ferrite beads I could use between the power supply output and the power supply pins of the GPRS module.
Regards.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jeferson Pehls
    on Aug 08 2012 19:57 PM
    Help?
    Report Abuse
    • Reply
  • Marc Davis-Marsh
    Posted by Marc Davis-Marsh
    on Aug 10 2012 11:11 AM
    Intellectual2970 points
    Hi Jeferson,
    THe LM22680 should work for this design, but because of the high frequency noise spec you will need to be very careful with layout and the output filter componenents.
    I asked someone to take a look at this design in more detail, and they should have some more information next week.
    Marc
    Report Abuse
    • Reply
  • Jeferson Pehls
    on Aug 10 2012 11:51 AM
    Hi.
    And how about the LM2676 for this design? It has a fixed switching frequency of 260Khz.
    And if I use a LM22680 for the new design, which switching frequency range would be suitable for GPRS? I know it has adjustable frequency, up to 1MHz
    Report Abuse
    • Reply
  • Jeferson Pehls
    on Aug 16 2012 21:00 PM
    Hi.
    Do you know when this person will be able to help me? I want to start updating the hardware soon.
    Report Abuse
    • Reply
  • Giuseppe Pinto
    Posted by Giuseppe Pinto
    on Aug 17 2012 16:20 PM
    Expert3815 points
    Hello Jeferson,
    we are working on it and we'll let you know as soon as possible.
    Giuseppe
    Report Abuse
    • Reply
  • Jeferson Pehls
    on Aug 17 2012 22:38 PM
    Hi.
    Thanks.
    We really need a good solution for this case, because we will update the hardware of a current design, and we have a relative high volume for this product.
    If the results with this new hardware be good, we would like to use the same power supply for all of our products based in GPRS/GSM. We are looking for a single solution for all products. We have many many products in development needing this solution.
    Regards.
    Report Abuse
    • Reply
  • Giuseppe Pinto
    on Aug 20 2012 18:07 PM
    Verified Answer
    Verified by Giuseppe Pinto
    Expert3815 points
    Hello Jeferson,
    I have tested the following circuit with the LM22680:
    The circuit seems to work fine and it meets the requirements.
    The switching frequency is 500kHz.
    Please see attached images for ripple constraints.
    8738.LM22680.zip
    Please let me know if you have any question.
    Giuseppe
    Report Abuse
    • Reply
  • Jeferson Pehls
    on Aug 20 2012 20:41 PM
    Hi.
    What was the value used for R3?
    I have one LM22680EVAL PCB and around 10 ICs samples of LM22680
    I have the capacitor below in one of our stock items. I can use it as output capacitor, in parallel with some ceramics.
    470uF, 10V, LOW Impedance: http://www.digikey.com/product-detail/en/EEE-FK1A471P/PCE3780TR-ND/765950
    I dont want to use the inductor of the EVM, I have 10 samples of each of these:
    10uH: http://www.digikey.com/product-detail/en/NR8040T100M/587-2001-2-ND/1739083
    22uH: http://www.digikey.com/product-detail/en/NR8040T220M/587-2002-2-ND/1739084
    33uH: http://www.digikey.com/product-detail/en/NR8040T330M/587-2636-2-ND/2349965
    47uH: http://www.digikey.com/product-detail/en/NR8040T470M/587-2003-2-ND/1739085
    I have more than 10 samples of these capacitors, to use at the input, in parallel with some ceramics
    INPUT CAPACITORS, ELECTROLYTIC:
    330uF, 35V, LOW Impedance: http://www.digikey.com/product-detail/en/EEE-FK1V331AP/PCE4429TR-ND/1141988
    470uF, 35V, LOW Impedance: http://www.digikey.com/product-detail/en/EEV-FK1V471Q/PCE3464TR-ND/396276
    For D1, I will use a B340A schottky (3A x 40V). It is a stock item.
    The input range will be from 10 to 31V only.
    Report Abuse
    • Reply
  • Giuseppe Pinto
    on Aug 21 2012 13:01 PM
    Expert3815 points
    Hello Jeferson,
    R3 is not present on the board, sorry for the misunderstanding. The LM22680 switches at 500kHz by default.
    For what concern the inductor i think that 10uH will be enough
    Please do not hesitate if you have any problem.
    Giuseppe
    Report Abuse
    • Reply
  • Jeferson Pehls
    on Aug 24 2012 23:02 PM
    Hi.
    Thanks for help.
    Is the LM2676 not suitable for this purpose?
    Report Abuse
    • Reply
  • Giuseppe Pinto
    on Aug 27 2012 12:09 PM
    Expert3815 points
    Hello Jeferson,
    the LM2676 should work fine, i can do some measurements within this week and i will let you know.
    Giuseppe
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
