hi
is it possible to change the out put voltage of the lm5576eval board, or to even make it flexible with cahning an resistor for an potentiometer? I need output volage between 5 and 14 Volts?
and another question: is there any difference between the lm25576eval board and the lm5576eval board.
could i just change the lm25576 against the lm5576 to get a higher range of input voltage up to 75 volts???
thanks in advance
gernot
