LM2679-adj connected in parallel
  • Hi Thomas,
    Can you clarify if you are asking for current sharing? If so, this is not a good idea since this part doesn't specifically support that. In fact, the part with the relatively higher output voltage will trump the other part.
    I am not sure why you hyperlinked a VICOR part into your question, but if you are looking for a current sharing module, you can try the LMZ23608 or LMZ23610.
    Hope this helps,
    Anston
