Hi Team,
I am using an LM62014 EVM and observed the following behavior. When applying ground to the shutdown pin, the device stops switching but the output voltage follows the input voltage.
I have looked at the LM62014 datasheet at the typical application circuit and this appears to be normal behavior for the circuit shown, but I want to verify that it is the same circuit on the EVM.
Is there a schematic for the LM62014 EVM? Does the design of the circuit on the EVM lend itself to that behavior? Do all boost topology converters have this same tendency?
