I am designing a 10V power supply using your LM2594HV-ADJ IC.
As mentioned in the datasheet, pin 5 has a !ON/OFF function and pins 1, 2 and 3 are not connected.
But in the 'typical PCB layout' for an adjustable output, in the same datasheet, pins 1 and 2 are connected to ground, pin 3 is connected to the Feedback line and the !ON/OFF pin, pin 5, is left floating.
So my question is, what do I do with these four pins?
Thank you in advance for the trouble to be taken.
