Hi, the datasheet for the LM2676 states that the on/off pin should be pulled high to enable the device but it doesn't specify if that should be done via a resistor or not.
Can I safely connect it directly to the DC input voltage which may be around 36v in my application or does it need special treatment?
Thanks.
