Hello all,
I have a tricky trouble whit TPS3306-18. I use this component whit a tri state buffer on pin WDI so i can use internal retrigger. Usually when pin is tri stated i see train of short pulse spaced by about 800 mS. This should be the internal retrigger pulse.
Now i found a board where this time is reduced to 1,4 mS and if microprocessor of my board try to toggle WDI pin it goes in reset. ( we have 200 mS square wave to refresh watchdog ).
I try to replace IC but i get the same behaviour. I try to disconnect pin 7 from board and nothing happen; internal refresh seems to be of 1.4 uS
Who is involved in the internal watchdog timing ? Why i found a so quick retrigger pulse ?
Thank in advance
Stefano
