I am designing in the TPS3823-33QDBVRQ1 to act as a watchdog timer and wanted to verify operation after power-up and before the processor boots up and toggles the WD pin. During the boot process the WD pin will be held high. Can I assume that the TPS3823-33's reset output will remain active high after VCC increases past VIT- threshold and stay there until the first transition of the WD pin. Is it this first transition at the WD pin which starts the watchdog timeout?
Mitch
