I have an application which has VDD = 0 volts (the TPS3701 is not powered) but a voltage applied to both INA and INB inputs through the standard 3 resistor divider as discussed in the data sheet. The question is what is the maximum voltage which can be applied to both INA and INB with VDD = 0 volts, and what is the expected input current draw? The data sheet values are unclear if they apply to VDD = 0 volts.
--Bill
