Other Parts Discussed in Thread: TPS3702-Q1, TPS3700
My Customer is doing timing verification of TPS3700-Q1 and TPS3702-Q1.
They want to do an accurate value calculation.
So, Do you have bellow min & max values of each device?
Taichi Nakamura,
We do not specify the min and max values since these values are not a tested parameter and can even vary slightly from device to device. The datasheet provides a typical range for propagation delay over temperature in Figure 5 and Figure 6. There is no available data for min/max for rise and fall times. I can work to get you an approximation but this will take some time.
Michael
