The voltage of the INA and INB inputs are limited to voltages between -.3 to +7 volts per spec. Is it correct to assume that there are two diodes connected to each input for static protection (clamping the input between approximately VDD and ground)? I would like to extend the range to -1 to +7 but would limit the current to 200 micro amps for the negative input voltages. Would this be possible?
--Bill
