Dears:
From the below schematic we design the R248 is 10K, however, the RESET pin's discretion from the datasheet is we should connect RESET using a 1k to 100k resistor to the correct pullup voltage rail(Vpu).
You know the internal resistor of RESET Pin is 100K, and we design a 10k resistor, then connecting RESET's resistor is 110k (100k add 10k).
What will happen some risk about the design?
Pls. give some advice about it.
Thanks a lot!
Best regards
Luck Wu
