• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Sequencers » Sequencers Forum » UCD90160
Share
Sequencers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
UCD90160
UCD90160
This question is answered
Alex Shpilsky
Posted by Alex Shpilsky
on Jul 12 2011 15:20 PM
Intellectual955 points
I am using Fusion Digital Power Designer GUI to program UCD90160. In addition to all the sequencing, I would like to generate a 1 second pulse on one of the GPIO pins, that gets trigered by an external event (that could be connected to one of the GPI pins). Can this be implemented?
In addition, is there a Linux Driver for UCD90160?
Alex
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eric Wright
    Posted by Eric Wright
    on Jul 13 2011 15:35 PM
    Verified Answer
    Verified by Eric Wright
    Mastermind20620 points
    Flub.pdf
    No on the Linux driver. Please see attached example for the pulse.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Jul 13 2011 16:21 PM
    Eric,
    Thank you. This is only possible for System Rest (GPIO14) pin. I was hoping to use a different GPIO pin.
    Alex
    Report Abuse
    • Reply
  • Eric Wright
    on Jul 13 2011 16:37 PM
    Verified Answer
    You can define any of the 22x GPIO pins as the System Reset pin. Do you have access to the Fusion GUI? You can download it and run it in offline mode (if you do not have EVM or other hardware). There is a UCD90160 sample project included which you can use to test/see various features.
    http://focus.ti.com/docs/toolsw/folders/print/fusion_digital_power_designer.html
    Latest Release: Fusion Digital Power Designer Version 1.8.80 [July 1, 2011]
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Aug 01 2011 22:20 PM
    Eric,
    What limits number of GPO to 16 maximum, when there are 22 possible GPIO available?
    Alex
    Report Abuse
    • Reply
  • Eric Wright
    on Aug 09 2011 21:38 PM
    Verified Answer
    It depends on what the GPO's are used for. Please use the Fusion GUI as a guide when selecting GPO's.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Sep 07 2011 19:38 PM
    The customer found UCD90124 Linux driver. Is the UCD90124 interface similar  to the UCD90160?  If so they could modify the existing UCD90124 driver.  Please advise.
    Report Abuse
    • Reply
  • Eric Wright
    on Sep 07 2011 22:04 PM
    Yes, the interfaces are similar.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Nov 22 2011 16:05 PM
    We have a UCD90160 that we programmed on-board using the TI Fusion GUI.  After we programmed the device we got locked out.  The Fusion GUI now tells us it can’t read the Device ID  and proceeds no further.  Any ideas about what might cause this?  Is there any way to reset things?
    Thank you.
    Report Abuse
    • Reply
  • Eric Wright
    on Nov 22 2011 18:07 PM
    UCD90160_Debug.zip
    Please run the attached diag tool and let me know the results. This will tell us what is wrong.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Nov 23 2011 11:24 AM
    Eric - some additional information from the customer.
    1.       We still have the board where Device ID generates an error and  the software tools won’t proceed beyond this.  Steve will run the diagnostic software as you requested to give you more information about this problem.
    2.       We powered on a second board and successfully connected with the Fusion software.  We then tried to import a Fusion project file that we had developed in the offline mode to use to program this virgin part.  However, the file did not import properly.  Only 6 of the 11 rails in the project imported and those 6 did not fully import.  The software indicated that 11 rails were imported successfully and gave no indication of a problem.  This imported file programmed into the part but the GUI only displayed the 6 rails, not 11 that the logs said were imported.
    3.       We then tried to build a new file from scratch using Fusion in the on-line mode.  This was successful except for one key problem.  The software would not let us use GPIO1 as an active low rail enable.  It would only allow GPIO1 to be an active high rail enable.  We were able to program GPIO2 as an active low rail enable but never GPIO1.  We would get a cryptic software error message when trying to set GPIO as an active low rail enable.  This is a problem for us that we can’t figure out.  Could it be a Fusion software bug?  We are using 11/17/11 Fusion software.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Nov 23 2011 12:09 PM
    The customer ran the diagnostics tools. Here is their response.
    I ran the diagnostic tools as per your instructions.  At step 4, when scanning for devices by DEVICE_ID, no devices were found.  At step 7, the tool prompts for a password.
    Additionally, when launching the Fusion GUI, we occasionally see an error message like the attached.  Usually the tool just reports that no devices were found, though.
    Report Abuse
    • Reply
  • Eric Wright
    on Nov 23 2011 13:06 PM
    Repair No Device Found using UCD3xxx Device GUI.doc
    The password has been provided offline. Additionally, I've attached a device repair procedure which can be used depending on the report of the device debug tool.
    With regard to the COMM errors reported above, this seems to me like another system device may be contending for the bus. Can you verify that there is no other device which may be corrupting the bus transactions?
    With regard to GUI errors, send the various projects (offline created, online created with GPIO1 enable polarity problem). We will have to attempt to re-create the issue here prior to correcting it. Additional debug will have to wait until next week due to the US Thanksgiving holiday.
    Report Abuse
    • Reply
  • Alex Shpilsky
    on Nov 29 2011 16:48 PM
    Eric,
    Thank you very much for all your help. We found the customer's problem. It was related to 3.3V rail dipping during power-on.
    The problem is resolved.
    Alex
    Report Abuse
    • Reply
  • malli arjun92486
    Posted by malli arjun92486
    on Dec 29 2011 00:55 AM
    Prodigy50 points
    We are using UCD90160 in One of our AMC designs as Power Sequencer for intel.
    We are one of the customer. we have requested schematic review through our indian contact (Velmurugan).
    We are facing one issue with UCD90160 Power Sequencer.
    MON1 pin of UCD90160 is always showing wrongly in Power Designer software.
    This is a simple resistor divider which gives 2.13V approx when Main Power for the AMC(12V) is there.
    But in Software GUI (Fusion Power Designer 1.8.140), we are seeing either 0V or 3.9V. that too very random.
    We have seen Prev post in Forum and we have downloaded the UCD90160_Debug.Zip. when we are trying to Run it is Prompting for Password.
    Can you help on this.
    I can give my complete details and Project details in a mail .
    Malli
    Report Abuse
    • Reply
  • malli arjun92486
    on Dec 29 2011 08:42 AM
    Prodigy50 points
    Sorry, I forgot to give my mail in previous Post,
    My Email Address : Mallikarjunarao.Kopanati@lntinfotech.com.
    Malli
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
