• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Sequencers » Sequencers Forum » TLV809 vs TPS3808 accuracy in monitoring a 12 volt line
Share
Sequencers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Marc Kellermann
Posted by Marc Kellermann
on Jul 25 2012 01:27 AM
Prodigy330 points
I am trying to monitor a 12 volt power rail and need a reset signal to be asserted when the system loses power. I need the reset singal to be asserted at no lower than 9.7 volts in all corner cases (assuming 1% accurate exernal resistors).
What is the recommended resistor values in the voltage divider to scale down the 12 volt rail to have a balance between accuracy and low current?
What is the maxium voltage a reset signal could be asserted at, given the reistor values determined above?
Can you please help me determine the above for both a TLV809 and a TPS3808
-Marc
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Darwin Fernandez
    Posted by Darwin Fernandez
    on Jul 30 2012 13:25 PM
    Verified Answer
    Verified by Darwin Fernandez
    Genius11740 points
    Hi Marc,
    Below is an application note that discusses the design considerations for the resistor divider. Basically, the current through the divider should be at least be 100x the leakage current into the device. This will yield the optimum accuracy for the least amount of current through the divider. This app note also discusses the accuracy of the SVS when the tolerance of the resistors is included.
    http://www.ti.com/lit/an/slva450/slva450.pdf
    For the pull-up resistor at the RESET output of the SVS, if there is no design requirements in the datasheet, the RESET voltage can be pulled up as high as the abs max rating of the RESET pin. However, it should be pulled up less than this so as to prevent damage to the device.
    Please let me know if this helps.
    Darwin
    Report Abuse
    • Reply
  • Marc Kellermann
    on Aug 27 2012 17:33 PM
    Verified Answer
    Verified by Marc Kellermann
    Prodigy330 points
    Darwin,
    Thank you for the help. I wanted to add some of the offline help you provided me to benefit others.
    Sources of inaccuracy
    The team identified three sources of inaccuracy for circuit there are as  follows:
    • Voltage ranges on which the device can be trigger, Vit in accuracy
    • External Resistor inaccuracy used to create the external voltage divider.
    • Internal Resistor Inaccuracy which can affect the leakage current and the effective R2 of the external voltage divider.
    Proposed circuit and accuracy
     Using the app note highlighted above as a guide we formulated a voltage divider that should draw 100 times the leakage current of the device to optimize the power vs. accuracy curve. Assuming a requirement to use E96 1% accurate resistors, below are the recommended resistor values to use:
    Device
    R1
    R3
    ADM809S
    4270
    1740
    TLV809L30
    3570
    1470
    TPS3808G33
    29100
    12900
    Using the above resistors the team calculated the minimum voltage a reset would happen, maximum voltage, and nominal voltage that would trigger a reset considering all three sources of inaccuracy above. These are highlighted in the table below.
    Vsense (min)
    Vsense (nom)
    Vsense (max)
    Accuracy
    ADM809s
    9.773742046
    10.19287736
    10.64698816
    8.57%
    TLV809L30
    9.769829302
    10.11711429
    10.49203562
    7.14%
    TPS3808G33
    9.802419951
    10.06518884
    10.41262094
    6.06%
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
