• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Sequencers » Sequencers Forum » UCD90120 JTAG and power supply query
Share
Sequencers
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Adrian Grindon
Posted by Adrian Grindon
on Sep 02 2009 17:13 PM
Expert6500 points
We are not using the JTAG interface.
 The data sheet implies that I need to put a pull-up on TMS & TDI and a pull-down on Trst_n guess this is for when using the JTAG interface
 But Since I am not using this interface, do I need to leave these signals floating ?
 I intend on putting a pull-up TDI, TCK,TMS & Trst_n
 Can you comment on this
·         Do I need them ?
·         As a min, what should I pull-up/pull-down
Do I need to put any filtering on the 3V3 supply to the part as it has analog circuits inside, ie a ADC
JTAG UCD90120
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eric Wright
    Posted by Eric Wright
    on Sep 04 2009 12:12 PM
    Verified Answer
    Verified by Eric Wright
    Mastermind20740 points
    Hello Adrian, I am a TI factory applications engineer supporting the UCD90120.
    If one were using the JTAG interface, then pullups on TMS and TDI along with a pulldown on TRST (bar) would be appropriate. Since TMS, TDI, TCK, TDO also serve as GPIO pins pull them to the preferred "high impedance" level if you are using them. It is good practice to pulldown TRST (bar) with a 10K resistor.
    Listed below is the recommended power supply filtering for the UCD90120:
    Layout guidelines
    The thermal pad provides a thermal and mechanical interface between the device and the printed circuit board (PCB). While device power dissipation is not of primary concern, a more robust thermal interface can help the internal temperature sensor provide a better representation of PCB temperature. Connect the exposed thermal pad of the PCB to the device V
    SS pins and provide at least a 4 x 4 pattern of PCB vias to connect the thermal pad and VSS pins to the circuit ground on other PCB layers.
    For supply voltage decoupling, provide power supply pin bypass to the device as follows:
    0.1F, X7R ceramic in parallel with 0.01F, X7R ceramic at pin 47 (BPCAP)
    0.1F, X7R ceramic in parallel with 4.7F, X5R ceramic at pin 44 (V33D)
    0.1F, X7R ceramic at pin 7 (V33DIO)
    0.1F, X7R ceramic in parallel with 4.7F, X5R ceramic at pin 46 (V33A)
    Depending on use and application of the various GPIO signals used as digital outputs, some impedance control may be desired to quiet fast signal edges. For example, when using the FPWM pins for fan control or voltage margining the pin will be configured as a digital “clock” signal. Route these signals away from sensitive analog signals. It is also good design practice to provide a series impedance of 20-33 ohms at the signal source to slow fast digital edges.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
