Hi
Could you tell me the clock cycle accuracy at the LM3881.
I will use 10nF
min:
typ:1.2ms
max:
masa
Hi
I will use 10nF
min:
typ:1.2ms
max:
masa
Hi Masa,
Clock cycle accuracy is great. The only variation that will be seen is across wide temp. So at -40C and 125C, there will be around a 10-15% variation in delay time from the nominal value.
I recommend using an X7R cap rated at atleast 16V. You shouldn't see too much variation if your temp range falls well within the max.
Shashank
