UCD9090 Fault Response
Other Parts Discussed in Thread: UCD9090
I am using a UCD9090 and can verify that when a voltage drops below my under voltage threshold it gives an UV_FAULT and turns off the rail and its slaves. A problem I have is that there is a board we have that has a bad rail that never starts up so clearly it is below the threshold, but the rail never gives an UV_FAULT so it doesn't shut anything else off and the boards reports that everything is good. How do I fix this?
