We are planning to use the UCD9081 as a voltage monitor only (i.e. not as a sequencer). The rails will be monitored during system steady state operation only.
We plan on monitoring the system input voltage (12V). However, there will be a time during power up when the monitored 12V rail will apply some voltage at one of the MON pins while the IC is not supplied (couple of ms).
Is there any risk of voltage leakage or component damage with this implementation?
Thank you,
Cedrick
