Hi Team,
Good afternoon, my customer is using two of the UCD90160s in their design. They have seen inconsistent issues with the device responding with all Fs and is looking deeper at the timing parameters.
Along with this, we have a couple questions:
- How will the device behave if the I2C line is held low for longer than 35ms between the command cycle and read cycle?
- What is the best way to recover from a case where the device responds with bad data (all Fs for instance)?
- In some cases after the bad data has been sent, the following transfers are also messed up or NACed
Thank you!
~John
