I have a same problem with
http://e2e.ti.com/support/power_management/power_interface/f/204/p/262224/1185310.aspx#1185310
If the ON/OFF pin is low level, the output voltage is about 1.7V. This chip will provide power for a bluetooth module and a camera module. If without any load, the output voltage will be 0.8V.
Also I tried the TPS2702L. I get a same result.
Can you give me some suggestion to fix this problem?
Thank you
Fei
