Hi
Hi
Hi Takahiko,
1. In Auto-Retry mode, dVdT works while re-starting during auto-retry after a fault or Thermal Shutdown. During startup dVdT is charged witht constant ramp rate. Other than startup, lets say if output is restarting after a fault, output is still always charged with dVdT ramp rate. Others can be a SHDNb recycling, UVLO or OVP event.
2. If Tj is over TSD, and I(CB) < ILOAD < IFASTRIP, device will enter thermal shutdown.
3. Output voltage droop depends on the load you are putting on the output. If it is Resistive load, Output voltage will settle at I_Limit*R. But for active load it is little tricky. Let me know if you are using an active load.
Please get back if you need more clarifications on the above items.
Kari.
Hi Kari-san
Thermal_Stress_in_TPS2660_eFuse.pdfHi Yokoto,
Please find the attached document explaining thermal stress of TPS26660 while operating in currrent limit with auto-retry and circuit breaker with auto-retry.
Let me know if you need further information regarding this.
Kari.
Hi Kari-san
