TPS2660: behavior of the FLT pin
Part Number: TPS2660
My customer wants to know about the behavior of FLT.
The attachment is the graph of Vin, Vout, FLT, Iout when it was turned on.
Please let me know why the FLT turned low.
HayashiTPS26600 FLT .pdf
  • Hi Hayashi,
    I have looked at the graph of the FLT behaviour and it is not expected to go low after powering up.
    Can you please tell what is the pull up resistor from FLTb to 5V ?
    Does the customer see this problem everytime he powers the system?
    Does this happen in a special case? Please help to explain the scenario when the customer sees this FLTb behaviour.
    Kari.
  • In reply to Karikalan Selvaraj:
    Kari san
    Thank you for your advice.
    I answer your question.
    >They pull up resistor at 10 ohm from FLTb to 5V.
    >When it is no load, every time happen.
    If you want to check the circuit, would you mind to send me email?
    I will send you it
    My address : ta-hayashi@fujiele.co.jp
    Best regards.
    Hayashi
  • In reply to Hayashi:
    Hi Hayashi,
    Thank you.
    I have sent an email in this regard.
    Kari.
