Other Parts Discussed in Thread: CSD19506KTT
i would like to have a confirmation from profi. in this field. I'm developing a PCB which needs separate some loads from power supply. The power supply are Super-Capatitors (voltage variates 24-60V) and the current can go up to 25A. Relay can't be used, while the switching is happening every couple minutes in that case i tried to fined a suitable High End Switch, at the end no luck.
So the next move is to find suitable MOSFET driver and MOSFET for my PCB. My question is:
1) Can TPS2491 work with CSD19506KTT?
2) In TPS2491 calculator I came that I need to use 2x CSD19506KTT, to reduce disipation on MOSFETs (see attachment). How to make parallel connection?
3) Is there better solution?
Thank you.
Adnan
