Customer is considering TPS25942A for hot swap.
Customer TPS25942A usage condition is :
0 : Master(Vin) < Slave(Vout) condition
1 : Set the master side to diode mode
2 : After 1, turn on the slave side
I got two questions about this usage.
Q1 : When the master side PGTH rises with the power supply voltage on the Slave side,
Does PGOOD on the master side work?
(When TPS25942A is used in Diode mode,Does the PGOOD comparator operate with the voltage of PGTH?)
Q2 : In this usage mode, the master side is in the Vin < Vout state.
Is there a problem with this condition?
Is there a protection circuit against reverse voltage?
Could you give me your advice?
Yusuke/Japan Disty
